[postgis-devel] [PostGIS] #1663: ST_Summary output contains a spurious "+" sign
PostGIS trac at osgeo.org
Wed Mar 7 09:05:36 PST 2012
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 strk=# select ST_Summary('POINT(0 0)'::geometry);
  st_summary
  Point[]   +
 (1 row)
 This is against postgresql 9.1, with:
  POSTGIS="2.0.0beta2SVN" GEOS="3.3.2dev-CAPI-1.7.2" PROJ="Rel. 4.8.0, 20
 February 2012" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.6"
 SVN_REVISION=9419 USE_STATS (procs from 2.0 r0 need upgrade)
 NOTE: can't upgrade because "cannot drop function
 addgeometrycolumn(character varying,character varying,character
 varying,character varying,integer,character varying,integer,boolean)
 because extension postgis requires it"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1663>
