[postgis-devel] Add-DropOverviewConstraints are not documented
dustymugs dustymugs at gmail.com
Wed Mar 7 14:03:40 PST 2012
Yes, you are correct.  (Add|Drop)RasterConstraints is not documented.
Can you file a ticket for those two?
-bborie
On 03/07/2012 01:48 PM, Jose Carlos Martinez Llario wrote:
> Hi, yes that is what I meant.
> Using ST_resample I can manage my own spatial raster tables to make
> overviews.
> Then next step will be to use addrasterconstrains and
> addoverviewconstraints.
> Am I missing something?
> If not, we dont need these functions to be documented?
> On 07/03/2012 22:46, dustymugs wrote:
>> Jose,
>> I don't believe there is a function yet for generating overviews from
>> an existing raster layer. You can do something like it though using
>> ST_Resample(ST_Union(...)).
>> (Add|Drop)OverviewContraints is for applying the flags/constraints
>> that indicate a raster column as an overview of another table.
>> -bborie
>> On 03/07/2012 01:35 PM, Jose Carlos Martinez Llario wrote:
>>> Hi,
>>> If one want to make an overview from an already existing raster layer I
>>> guess we should use AddOverviewConstraints.
>>> Should AddOverviewConstraints and DropOverviewConstraints be documented?
>>> Best,
>>> Jose
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
