[postgis-devel] R: Re: raster2pgsql error?
dustymugs dustymugs at gmail.com
Wed Mar 7 16:59:31 PST 2012
What python commands are you using in the QGIS python console?  Since
you are getting output from ST_SummaryStats, we know that the data is
present in PostGIS Raster.  The problem is definitely in the GDAL side...
-bborie
On 03/07/2012 03:57 PM, Salvatore Larosa-1 wrote:
> Hi,
> i have rebuild gdal (r24093), but i get the same error!
> my configuration:
> *sam at debian:~$ gdal-config --version*
> 1.9.0
> *sam at debian:~$ gdal-config --formats*
> gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 xpm sdts raw dted mem jdem
> envisat elas fit vrt usgsdem l1b nitf bmp pcidsk airsar rs2 ilwis rmf
> leveller sgi srtmhgt idrisi gsg ingr ers jaxapalsar dimap gff cosar pds adrg
> coasp tsx terragen blx msgn til r northwood saga xyz hf2 kmlsuperoverlay ozi
> ctg e00grid zmap ngsgeoid wcs wms grib bsb ecw jpeg2000 netcdf hdf5 hdf4 gif
> jpeg png pcraster rik rasterlite mbtiles postgisraster
> *workshop=# SELECT postgis_full_version();*
>   POSTGIS="2.0.0beta3SVN r9427" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.7.1, 23
> September 2009" GDAL="GD
> AL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
> (1 row)
> Not sure if the output of gdal-config --version is correct!
> should I get the revision number?
> View this message in context: http://postgis.17.n6.nabble.com/R-Re-raster2pgsql-error-tp4555702p4556919.html
> Sent from the PostGIS - Dev mailing list archive at Nabble.com.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
