[postgis-devel] [PostGIS] #1667: [raster] raster regress failures
PostGIS trac at osgeo.org
Thu Mar 8 07:21:38 PST 2012
 Reporter:  robe                      |       Owner:  pracine
     Type:  defect                    |      Status:  new
 Priority:  blocker                   |   Milestone:  PostGIS 2.0.0
Component:  raster                    |     Version:  trunk
 Keywords:  windows 32-bit, mingw345  |
Comment(by dustymugs):
 Based upon the output you're getting, it looks like you're having the same
 issue that pramsey emailed me about.  Try the following on the command
 line...
 gdalsrsinfo.exe EPSG:2163
 If you get output like
 ERROR 1: ERROR - failed to load SRS definition from EPSG:2163
 something is wrong with your GDAL environment.  I don't know if pramsey
 resolved his issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1667#comment:3>
