[postgis-devel] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
PostGIS trac at osgeo.org
Thu Mar 8 08:07:50 PST 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  mingw64  |
Comment(by robe):
 reran check and Cunit consistently crashes on:
  Test: out_kml_test_geoms ...
 I do note that when I was trying ST_AsKML it was outputting blanky.
 -- this test --
 SELECT ST_AsKML(ST_Buffer(ST_GeomFromText('POINT(1
 2)',4326),1,'quad_segs=3'));
 -- run on my PostGIS 2.0.0 beta2 mingw64 --
 returns nothing
 -- run on my PostGIS 1.5.3 mingw64 --
 returns:
 <Polygon><outerBoundaryIs><LinearRing><coordinates>2,2
 1.866025403784439,1.5 1.500000000000001,1.133974596215562
 1.000000000000001,1 0.500000000000002,1.13397459621556
 0.133974596215563,1.499999999999998 0,1.999999999999997
 0.133974596215559,2.499999999999996 0.499999999999997,2.866025403784437
 0.999999999999995,3 1.499999999999996,2.866025403784441
 1.866025403784436,2.500000000000005
 2,2</coordinates></LinearRing></outerBoundaryIs></Polygon>
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:3>
