[postgis-devel] [PostGIS] #1669: Missing street type w/ Internal component makes geocode() so SLOOOW
PostGIS trac at osgeo.org
Thu Mar 8 08:12:32 PST 2012
 Reporter:  mikepease  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.1
Component:  postgis    |     Version:  1.5.X
 Keywords:             |
 It appears there are certain types of address strings that make the
 geocode() function run 100 - 1000X slower than "normal addresses".
 Consider these variations on[[BR]]
 51 Nicollet Ave FL 4, Minneapolis, MN 55402
 select (addy).*, rating from geocode('651 Nicollet Ave FL 4, Minneapolis,
 MN 55402') -- Fast![[BR]]
 select (addy).*, rating from geocode('651 Nicollet FL 4, Minneapolis, MN
 55402')  -->SLOW! 60+sec[[BR]]
 select (addy).*, rating from geocode('651 Nicollet, FL 4, Minneapolis, MN
 select (addy).*, rating from geocode('651 Nicollet, Minneapolis, MN
 55402')  --Fast![[BR]]
 From what I can surmise, it seems that if you have an address that DOESN'T
 specify the street type but DOES specify an internal component, then the
 big slow-down happens.
 When I run a list of several thousand addresses of medium quality, I run
 into dozens or more of these slow addresses and it ends up taking a
 majority of the time to run through these addresses.
 Say I have a list of 10,000 medium-quality addresses.
 Maybe 9,950 of them will run fine, but just 50 of them go slow.
 This tiny minority ends up taking the vast majority of the batch time.
 9,950 x 0.1 sec = ~15 min.
 50 x 90 sec = 75 min.
 Total ~90 min.
 Given the effect this has on running through a list, I think it's
 important to find a fix for this.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1669>
