[postgis-devel] [PostGIS] #1676: Problem in converting from RT90(SRID=3021) to WGS84(SRID=4326)
PostGIS trac at osgeo.org
Sat Mar 10 04:54:29 PST 2012
 Reporter:  arashamiri  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  high        |   Milestone:  PostGIS 1.4.3
Component:  postgis     |     Version:  1.5.X
 Keywords:              |
Comment(by strk):
 It is PROJ that matters here, and proj4text entry in spatial_ref_sys.
 Compare the two proj4text values for SRIDS 3021 and 4326 and see if they
 differ.
 Also report version of PROJ (select postgis_full_version() should tell
 you)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1676#comment:1>
