[postgis-devel] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
PostGIS trac at osgeo.org
Sat Mar 10 10:42:30 PST 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  mingw64  |
Comment(by robe):
 Nope -- with your solution, the wkt out tests works but the KML one still
 crashes.
 I think the issue is that you are not allocating space when len < 0
 So this line you have here
 stringbuffer_makeroom(s, len + 1);
 becomes
 stringbuffer_makeroom(s, 0);
 Which happens to work for the wkt out case because you make_room function
 overshoots adding an extra 2 or so above length
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:18>
