[postgis-devel] PostGIS 2.0.0beta2 working for me...
Salvatore Larosa lrssvtml at gmail.com
Sun Mar 11 03:23:18 PDT 2012
Unfortunately, I can't tell the same!
Only topology and raster regression tests is right for me!
In core I get 20 error:
PostgreSQL 9.1.2 on x86_64-unknown-linux-gnu, compiled by gcc (Debian
4.6.2-12) 4.6.2, 64-bit
 Postgis 2.0.0beta3SVN - r9475 - 2012-03-09 20:31:33
   GEOS: 3.3.2-CAPI-1.7.2
   PROJ: Rel. 4.7.1, 23 September 2009
Running tests
 loader/Point ........ failed (dumper geog test: dumping loaded
table: /tmp/pgis_reg/dumper.err)
 loader/PointM ... failed ( wkt test: running shp2pgsql
output: /tmp/pgis_reg/loader.err)
 loader/PointZ ... failed ( wkt test: running shp2pgsql
 loader/MultiPoint ... failed ( wkt test: running shp2pgsql
 loader/MultiPointM ... failed ( wkt test: running shp2pgsql
 loader/MultiPointZ ... failed ( wkt test: running shp2pgsql
 loader/Arc ... failed ( wkt test: running shp2pgsql
 loader/ArcM ... failed ( wkt test: running shp2pgsql
 loader/ArcZ ... failed ( wkt test: running shp2pgsql
 loader/Polygon ... failed ( wkt test: running shp2pgsql
 loader/PolygonM ... failed ( wkt test: running shp2pgsql
 loader/PolygonZ ... failed ( wkt test: running shp2pgsql
 loader/TSTPolygon ... failed ( wkt test: running shp2pgsql
 loader/TSIPolygon ... failed ( wkt test: running shp2pgsql
 loader/TSTIPolygon ... failed ( wkt test: running shp2pgsql
 loader/PointWithSchema ..... ok
 loader/NoTransPoint ........ failed (dumper wkb test: dumping loaded
 loader/NotReallyMultiPoint ... failed ( wkt test: running shp2pgsql
 loader/MultiToSinglePoint ... failed ( wkt test: running shp2pgsql
 loader/ReprojectPts .... failed ( wkt test: running shp2pgsql
 loader/ReprojectPtsGeog .... failed ( wkt test: running shp2pgsql
 loader/Latin1 .... ok
 binary .. ok
 regress .. ok
 regress_index .. ok
 regress_index_nulls .. ok
 lwgeom_regress .. ok
 regress_lrs .. ok
 removepoint .. ok
 setpoint .. ok
 simplify .. ok
 snaptogrid .. ok
 summary .. ok
 affine .. ok
 empty .. ok
 measures .. ok
 legacy .. ok
 long_xact .. ok
 ctors .. ok
 sql-mm-serialize .. ok
 sql-mm-circularstring .. ok
 sql-mm-compoundcurve .. ok
 sql-mm-curvepoly .. ok
 sql-mm-general .. ok
 sql-mm-multicurve .. ok
 sql-mm-multisurface .. ok
 polyhedralsurface .. ok
 polygonize .. ok
 postgis_type_name .. ok
 out_geometry .. ok
 out_geography .. ok
 in_gml .. ok
 in_kml .. ok
 iscollection .. ok
 regress_ogc .. ok
 regress_ogc_cover .. ok
 regress_ogc_prep .. ok
 regress_bdpoly .. ok
 regress_proj .. ok
 regress_management .. ok
 dump .. ok
 dumppoints .. ok
 wmsservers .. ok
 wkt .. ok
 wkb .. ok
 tickets .. ok
 typmod .. ok
 remove_repeated_points .. ok
 split .. ok
 relate .. ok
 bestsrid .. ok
 concave_hull .. ok
 hausdorff .. ok
 regress_buffer_params .. ok
 offsetcurve .. ok
 relatematch .. ok
 isvaliddetail .. ok
 sharedpaths .. ok
 snap .. ok
 node .. ok
 unaryunion .. ok
 clean .. ok
 relate_bnr .. ok
 uninstall .. ok (3855)
Run tests: 84
Failed: 20
make[1]: *** [check] Error 20
make[1]: Leaving directory `/home/sam/pacchetti_gis/postgis-svn/regress'
make: *** [check] Error 1
Il giorno sab, 10/03/2012 alle 17.01 -0800, pcreso at pcreso.com ha
scritto:
> FWIW:
> Built & installed OK on OpenSuse 12.1 64 bit:
> PostgreSQL 9.1.1 on x86_64-suse-linux-gnu, compiled by gcc (SUSE
> Linux) 4.6.2, 64-bit
>  Postgis 2.0.0beta2 - r9428 - 2012-03-10 23:59:03
> Passed all regression tests (make check) for core, raster & topology:
> Works OK with imposm for OSM server:
> imposm --read --write --optimize -d osm --overwrite-cache
> newzealand.osm
> General queries (so far) work OK.
> Brent Wood
> --- On Thu, 3/8/12, Paul Ramsey <pramsey at opengeo.org> wrote:
>         From: Paul Ramsey <pramsey at opengeo.org>
>         Subject: [postgis-devel] PostGIS 2.0.0beta2
>         To: "PostGIS Users Discussion"
>         <postgis-users at postgis.refractions.net>,
>         postgis-devel at postgis.refractions.net
>         Date: Thursday, March 8, 2012, 10:06 AM
>         Hi All,
>         PostGIS 2.0.0beta2:
>         http://postgis.org/download/postgis-2.0.0beta2.tar.gz
>         Current open tickets: http://trac.osgeo.org/postgis/report/22
>         You'll note that the number of open tickets is getting close
>         to zero.
>         Like a rocket ship countdown, when we get to zero, we launch.
>         But we need your help now, more than ever. Please try out
>         PostGIS 2.0.
>         Download it, build it, move your databases to it, make sure it
>         works
>         for you.
>         Thanks!!!
>         _______________________________________________
>         postgis-devel mailing list
>         http://postgis.refractions.net/mailman/listinfo/postgis-devel
