[postgis-devel] PostGIS 2.0.0beta2 working for me...
Salvatore Larosa lrssvtml at gmail.com
Sun Mar 11 12:03:08 PDT 2012
in dumper.err:
could not connect to server: No such file or directory
	Is the server running locally and accepting
	connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
while, in loader.err:
SET
SET
BEGIN
psql:/tmp/pgis_reg/loader.out:5: NOTICE:  CREATE TABLE will create
implicit sequence "loadedshp_gid_seq" for serial column "loadedshp.gid"
CREATE TABLE
psql:/tmp/pgis_reg/loader.out:6: NOTICE:  ALTER TABLE / ADD PRIMARY KEY
will create implicit index "loadedshp_pkey" for table "loadedshp"
ALTER TABLE
INSERT 0 1
COMMIT
Why can not I connect to the server?
Il giorno dom, 11/03/2012 alle 11.18 -0700, Bborie Park ha scritto:
> Salvatore,
> Can you attach /tmp/pgis_reg/dumper.err and /tmp/pgis_reg/loader.err
> in a response to this email thread?
> -bborie
> On Sun, Mar 11, 2012 at 3:23 AM, Salvatore Larosa <lrssvtml at gmail.com> wrote:
> > Unfortunately, I can't tell the same!
> > Only topology and raster regression tests is right for me!
> > In core I get 20 error:
> > PostgreSQL 9.1.2 on x86_64-unknown-linux-gnu, compiled by gcc (Debian
> > 4.6.2-12) 4.6.2, 64-bit
> >  Postgis 2.0.0beta3SVN - r9475 - 2012-03-09 20:31:33
> >   GEOS: 3.3.2-CAPI-1.7.2
> >   PROJ: Rel. 4.7.1, 23 September 2009
> > Running tests
> >  loader/Point ........ failed (dumper geog test: dumping loaded
> > table: /tmp/pgis_reg/dumper.err)
> >  loader/PointM ... failed ( wkt test: running shp2pgsql
> > output: /tmp/pgis_reg/loader.err)
> >  loader/PointZ ... failed ( wkt test: running shp2pgsql
> >  loader/MultiPoint ... failed ( wkt test: running shp2pgsql
> >  loader/MultiPointM ... failed ( wkt test: running shp2pgsql
> >  loader/MultiPointZ ... failed ( wkt test: running shp2pgsql
> >  loader/Arc ... failed ( wkt test: running shp2pgsql
> >  loader/ArcM ... failed ( wkt test: running shp2pgsql
> >  loader/ArcZ ... failed ( wkt test: running shp2pgsql
> >  loader/Polygon ... failed ( wkt test: running shp2pgsql
> >  loader/PolygonM ... failed ( wkt test: running shp2pgsql
> >  loader/PolygonZ ... failed ( wkt test: running shp2pgsql
> >  loader/TSTPolygon ... failed ( wkt test: running shp2pgsql
> >  loader/TSIPolygon ... failed ( wkt test: running shp2pgsql
> >  loader/TSTIPolygon ... failed ( wkt test: running shp2pgsql
> >  loader/PointWithSchema ..... ok
> >  loader/NoTransPoint ........ failed (dumper wkb test: dumping loaded
> >  loader/NotReallyMultiPoint ... failed ( wkt test: running shp2pgsql
> >  loader/MultiToSinglePoint ... failed ( wkt test: running shp2pgsql
> >  loader/ReprojectPts .... failed ( wkt test: running shp2pgsql
> >  loader/ReprojectPtsGeog .... failed ( wkt test: running shp2pgsql
> >  loader/Latin1 .... ok
> >  binary .. ok
> >  regress .. ok
> >  regress_index .. ok
> >  regress_index_nulls .. ok
> >  lwgeom_regress .. ok
> >  regress_lrs .. ok
> >  removepoint .. ok
> >  setpoint .. ok
> >  simplify .. ok
> >  snaptogrid .. ok
> >  summary .. ok
> >  affine .. ok
> >  empty .. ok
> >  measures .. ok
> >  legacy .. ok
> >  long_xact .. ok
> >  ctors .. ok
> >  sql-mm-serialize .. ok
> >  sql-mm-circularstring .. ok
> >  sql-mm-compoundcurve .. ok
> >  sql-mm-curvepoly .. ok
> >  sql-mm-general .. ok
> >  sql-mm-multicurve .. ok
> >  sql-mm-multisurface .. ok
> >  polyhedralsurface .. ok
> >  polygonize .. ok
> >  postgis_type_name .. ok
> >  out_geometry .. ok
> >  out_geography .. ok
> >  in_gml .. ok
> >  in_kml .. ok
> >  iscollection .. ok
> >  regress_ogc .. ok
> >  regress_ogc_cover .. ok
> >  regress_ogc_prep .. ok
> >  regress_bdpoly .. ok
> >  regress_proj .. ok
> >  regress_management .. ok
> >  dump .. ok
> >  dumppoints .. ok
> >  wmsservers .. ok
> >  wkt .. ok
> >  wkb .. ok
> >  tickets .. ok
> >  typmod .. ok
> >  remove_repeated_points .. ok
> >  split .. ok
> >  relate .. ok
> >  bestsrid .. ok
> >  concave_hull .. ok
> >  hausdorff .. ok
> >  regress_buffer_params .. ok
> >  offsetcurve .. ok
> >  relatematch .. ok
> >  isvaliddetail .. ok
> >  sharedpaths .. ok
> >  snap .. ok
> >  node .. ok
> >  unaryunion .. ok
> >  clean .. ok
> >  relate_bnr .. ok
> >  uninstall .. ok (3855)
> > Run tests: 84
> > Failed: 20
> > make[1]: *** [check] Error 20
> > make[1]: Leaving directory `/home/sam/pacchetti_gis/postgis-svn/regress'
> > make: *** [check] Error 1
> > Il giorno sab, 10/03/2012 alle 17.01 -0800, pcreso at pcreso.com ha
> > scritto:
> >> FWIW:
> >> Built & installed OK on OpenSuse 12.1 64 bit:
> >> PostgreSQL 9.1.1 on x86_64-suse-linux-gnu, compiled by gcc (SUSE
> >> Linux) 4.6.2, 64-bit
> >>  Postgis 2.0.0beta2 - r9428 - 2012-03-10 23:59:03
> >> Passed all regression tests (make check) for core, raster & topology:
> >> Works OK with imposm for OSM server:
> >> imposm --read --write --optimize -d osm --overwrite-cache
> >> newzealand.osm
> >> General queries (so far) work OK.
> >> Brent Wood
> >> --- On Thu, 3/8/12, Paul Ramsey <pramsey at opengeo.org> wrote:
> >>         From: Paul Ramsey <pramsey at opengeo.org>
> >>         Subject: [postgis-devel] PostGIS 2.0.0beta2
> >>         To: "PostGIS Users Discussion"
> >>         <postgis-users at postgis.refractions.net>,
> >>         postgis-devel at postgis.refractions.net
> >>         Date: Thursday, March 8, 2012, 10:06 AM
> >>         Hi All,
> >>         PostGIS 2.0.0beta2:
> >>         http://postgis.org/download/postgis-2.0.0beta2.tar.gz
> >>         Current open tickets: http://trac.osgeo.org/postgis/report/22
> >>         You'll note that the number of open tickets is getting close
> >>         to zero.
> >>         Like a rocket ship countdown, when we get to zero, we launch.
> >>         But we need your help now, more than ever. Please try out
> >>         PostGIS 2.0.
> >>         Download it, build it, move your databases to it, make sure it
> >>         works
> >>         for you.
> >>         Thanks!!!
> >>         _______________________________________________
> >>         postgis-devel mailing list
> >>         http://postgis.refractions.net/mailman/listinfo/postgis-devel
