[postgis-devel] [PostGIS] #1679: Intersect give ERROR: AddToPROJ4SRSCache
PostGIS trac at osgeo.org
Mon Mar 12 07:10:59 PDT 2012
 Reporter:  andreasft  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
 Intersecting two gemetries (casted to geography) and calculating the sum
 of this intersection in sq.km return this error:
 ERROR:  AddToPROJ4SRSCache: couldn't parse proj4 string: '+proj=utm
 +zone=0 +south +ellps=WGS84 +datum=WGS84 +units=m +no_defs': invalid UTM
 zone number
 ********** Error **********
 ERROR: AddToPROJ4SRSCache: couldn't parse proj4 string: '+proj=utm +zone=0
 +south +ellps=WGS84 +datum=WGS84 +units=m +no_defs': invalid UTM zone
 number
 SQL state: XX000
 The query:
 select p.gid, SUM(ST_Area(ST_Intersection(p.cell::geography,
 c.geom::geography)))/1000^2 AS landarea FROM cshapeswdatevalid c,
 priogrid_land p WHERE ST_Intersects(p.cell::geography, c.geom::geography)
 AND c.gwsyear <= 2008 AND c.gweyear >= 2008
 GROUP BY p.gid ORDER BY p.gid;
 svn, rev 9240
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1679>
