[postgis-devel] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
PostGIS trac at osgeo.org
Mon Mar 12 08:32:59 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  mingw64  |
Comment(by pramsey):
 I implemented the portable snprintf  over the weekend, but have been
 saddened to find that it doesn't quite behave as advertised on 1e300,
 which is an example in the KML cunit tests. So I'm going to poke it a few
 more times and see if there's a way around, and then try your workaround.
 Is there a #define that the mingw64 compiler sets? _WIN64 seems overly
 broad (though I could use that one).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:22>
