[postgis-devel] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
PostGIS trac at osgeo.org
Mon Mar 12 17:09:49 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  mingw64  |
Comment(by robe):
 nope -- doesn't compile. Sadly unless I'm doing something wrong,
 replacing my mingw with a newer version didn't help either.  Perhaps I
 should just try to cut in that patch I found (if only I had bookmarked
 it).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:26>
