[postgis-devel] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
PostGIS trac at osgeo.org
Mon Mar 12 17:16:02 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  mingw64  |
Comment(by robe):
 BTW Hudson is not happy either, but in a different way -- log from Hudson.
 Perhaps we should just put things back the way they were for now.
 Updating http://svn.osgeo.org/postgis/trunk
 D         postgis/compat.h
 G         raster/rt_pg/rt_pg.c
 U         configure.ac
 U         libpgcommon/lwgeom_pg.c
 U         liblwgeom/Makefile.in
 G         liblwgeom/stringbuffer.c
 G         liblwgeom/cunit/cu_out_kml.c
 U         liblwgeom/vsprintf.c
 AU        liblwgeom/snprintf.c
 U         liblwgeom/lwgeom_geos.c
 G         liblwgeom/liblwgeom.h.in
 U         liblwgeom/liblwgeom_internal.h
 AU        macros/snprintf.m4
 U         postgis_config.h.in
 At revision 9477
 [workspace] $ /bin/sh -xe /tmp/hudson3794278016352853331.sh
 ++ svn info src
 ++ grep 'Last Changed Rev:'
 ++ cut -f4 '-d '
 + SVN_REVISION=9477
 + rm -rf build
 + rm -rf rel
 + rm -rf postgis-2.0.0beta3SVN postgis-2.0.0beta3SVN.tar.gz
 + svn export src rel
 Export complete.
 + cd ./rel
 + ./autogen.sh
 * Running /usr/bin/libtoolize (1.5.22)
    OPTIONS = --force --copy
 You should add the contents of `/usr/share/aclocal/libtool.m4' to
 `aclocal.m4'.
 * Running /usr/bin/aclocal (1.9.6)
 configure.ac:43: error: Autoconf version 2.60 or higher is required
 macros/snprintf.m4:19: HW_HEADER_STDARG_H is expanded from...
 configure.ac:43: HW_HEADER_STDARG_H is required by...
 macros/snprintf.m4:57: HW_FUNC_VA_COPY is expanded from...
 configure.ac:43: the top level
 autom4te: /usr/bin/m4 failed with exit status: 63
 aclocal: autom4te failed with exit status: 63
   Something went wrong, giving up!
 Archiving artifacts
 Sending e-mails to: chodgson at refractions.net pramsey at cleverelephant.ca
 Notifying upstream projects of job completion
 Finished: FAILURE
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:28>
