[postgis-devel] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
PostGIS trac at osgeo.org
Tue Mar 13 05:03:35 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  mingw64  |
Comment(by mcayland):
 Hang on guys, wait a second. MingW already comes with a set of wrappers
 around the MSVCRT routines that aren't 100% compliant which can get
 substituted at compile time to gain the correct behaviour if we need it.
 Hence we shouldn't need to be adding our own versions of functions like
 this to the repository until the point where people want to build this
 stuff on other compilers, e.g. MSVC.
 The patch referenced by Regina above suggests that we can enable the MingW
 wrappers for broken MSVCRT functions by simply adding
 "-D__USE_MINGW_ANSI_STDIO" to both the compile/link command line - see
 some of the notes at
 http://sourceforge.net/project/shownotes.php?release_id=24832 for further
 information.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:32>
