[postgis-devel] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
PostGIS trac at osgeo.org
Tue Mar 13 09:11:28 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  mingw64  |
Comment(by robe):
 Mark,
 I tried doing this thinking the same thing, but evidentally I'm not doing
 it right since it made no difference: ignore my PROJECTS, PG_VER variables
 CPPFLAGS="-I${PROJECTS}/pgx64/pg${PG_VER}/include
 -D__USE_MINGW_ANSI_STDIO=1" LDFLAGS="-L${PROJECTS}/pgx64/pg${PG_VER}/lib
 -L${PROJECTS}/gdal/rel-${GDAL_VER}/lib" ./configure ..other stuff
 BTW I think that is why the loader is broken, but the raster2pgsql one is
 broken because of the gettext issue (so trying to build that one from
 scratch).  If I don't specify a schema the raster2pgsql one works fine.
 On closer inspection looks like shp2pgsql is also using string_buffer.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:36>
