[postgis-devel] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
PostGIS trac at osgeo.org
Tue Mar 13 09:32:13 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  mingw64  |
Comment(by mcayland):
 I see you've added it to CPPFLAGS but I think you may also need to add it
 to LDFLAGS too? AFAICT the headers will be affected by the CPPFLAGS,
 however the linker also needs to told to pull in the modified MingW
 library routines too.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:38>
