[postgis-devel] Problem buiding on Windows
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Tue Mar 13 13:49:29 PDT 2012
Am I the only one having this problem building on Windows 7 with the old MinGW 3.4.5?
gcc -O2 -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-statement -Wendif-labels -Wformat-security -fno-strict-aliasing -fwra
pv  -I/c/projects/geos/rel-3.3.2/include -I/c/projects/pg/pg90/include  -I/c/projects/libxml/libxml2-2.7.8release/include/libxml2 -I../liblw
geom -I../libpgcommon -I. -I. -Ic:/projects/pg/pg90/include/POSTGR~1/server -Ic:/projects/pg/pg90/include/POSTGR~1/internal -I./src/include/
port/win32 -DEXEC_BACKEND  "-Ic:/projects/pg/pg90/lib/POSTGR~1/pgxs/src/MAKEFI~1/../../src/include/port/win32" -Ic:/projects/pg/pg90/include
/POSTGR~1/server/port/win32  -c -o lwgeom_box3d.o lwgeom_box3d.c
lwgeom_box3d.c: In function `BOX3D_in':
lwgeom_box3d.c:104: error: structure has no member named `srid'
lwgeom_box3d.c: In function `BOX3D_to_LWGEOM':
lwgeom_box3d.c:246: error: structure has no member named `srid'
lwgeom_box3d.c: In function `LWGEOM_to_BOX3D':
lwgeom_box3d.c:296: error: structure has no member named `srid'
lwgeom_box3d.c: In function `BOX3D_combine':
lwgeom_box3d.c:396: error: structure has no member named `srid'
lwgeom_box3d.c:407: error: structure has no member named `srid'
lwgeom_box3d.c: In function `BOX3D_construct':
lwgeom_box3d.c:445: error: structure has no member named `srid'
make[1]: *** [lwgeom_box3d.o] Error 1
make[1]: Leaving directory `/c/projects/postgis/postgis'
make: *** [all] Error 1
Thanks,
Pierre
