[postgis-devel] Problem buiding on Windows
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Tue Mar 13 14:00:29 PDT 2012
But I just checked out everything from scratch...
Anything else has to be updated? You build with MinGW-w64 right?
Anybody tried recently with the MinGW 3.4.5?
Pierre
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
> Sent: Tuesday, March 13, 2012 4:54 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Problem buiding on Windows
> Seems like. It looks very much like liblwgeom.h has not been regenerated from
> liblwgeom.h.in in some time.
> P.
> On Tue, Mar 13, 2012 at 1:49 PM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> wrote:
> > Am I the only one having this problem building on Windows 7 with the old
> MinGW 3.4.5?
> > gcc -O2 -Wall -Wmissing-prototypes -Wpointer-arith
> > -Wdeclaration-after-statement -Wendif-labels -Wformat-security
> > -fno-strict-aliasing -fwra pv  -I/c/projects/geos/rel-3.3.2/include
> > -I/c/projects/pg/pg90/include
> > -I/c/projects/libxml/libxml2-2.7.8release/include/libxml2 -I../liblw
> > geom -I../libpgcommon -I. -I.
> > -Ic:/projects/pg/pg90/include/POSTGR~1/server
> > -Ic:/projects/pg/pg90/include/POSTGR~1/internal -I./src/include/
> > port/win32 -DEXEC_BACKEND
> > "-Ic:/projects/pg/pg90/lib/POSTGR~1/pgxs/src/MAKEFI~1/../../src/includ
> > e/port/win32" -Ic:/projects/pg/pg90/include
> > /POSTGR~1/server/port/win32  -c -o lwgeom_box3d.o lwgeom_box3d.c
> > lwgeom_box3d.c: In function `BOX3D_in':
> > lwgeom_box3d.c:104: error: structure has no member named `srid'
> > lwgeom_box3d.c: In function `BOX3D_to_LWGEOM':
> > lwgeom_box3d.c:246: error: structure has no member named `srid'
> > lwgeom_box3d.c: In function `LWGEOM_to_BOX3D':
> > lwgeom_box3d.c:296: error: structure has no member named `srid'
> > lwgeom_box3d.c: In function `BOX3D_combine':
> > lwgeom_box3d.c:396: error: structure has no member named `srid'
> > lwgeom_box3d.c:407: error: structure has no member named `srid'
> > lwgeom_box3d.c: In function `BOX3D_construct':
> > lwgeom_box3d.c:445: error: structure has no member named `srid'
> > make[1]: *** [lwgeom_box3d.o] Error 1
> > make[1]: Leaving directory `/c/projects/postgis/postgis'
> > make: *** [all] Error 1
> > Thanks,
> > Pierre
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
