[postgis-devel] [PostGIS] #1684: Option to disable comments building
PostGIS trac at osgeo.org
Wed Mar 14 05:02:56 PDT 2012
 Reporter:  robe         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.1
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by strk):
 ok, back on the analysis:
 my "make" isn't descending in the doc/ directory. is yours ?
 consequently, "make install" doesn't try either.
 "make check" is the only one that tries, due to an explicit request about
 testing comments,
 which I think makes sense for those running "make check".
 So, this ticket sounds kind of misleading as we don't really need an
 option to disable comments building because comments building are built
 explicitly. That's to say the ticket should mention running "make check"
 or something. Or are you really having problems unrelated to "make check"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1684#comment:3>
