[postgis-devel] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
PostGIS trac at osgeo.org
Wed Mar 14 06:26:41 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  trunk
 Keywords:  mingw64  |
Comment(by robe):
 okay sadly none of these worked, however, I was able to find a good
 workaround.
 Taking tips from this:
 http://stackoverflow.com/questions/8488671/unix-to-windows-alternative-to-
 vsnprintf-to-determine-length
 I used this function:
 http://msdn.microsoft.com/en-us/library/w05tbk72%28VS.71%29.aspx
 To determine the correct size to allocate.  Just don't know how to make
 this a conditional define.
 so my workaround looks like this:
 if ( len < 0 )
         len = _vscprintf(fmt, ap2);/**Assume windows and compute space **/
 That fixed my issue of being able to load large polygons with shp2pgsql.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:43>
