[postgis-devel] [PostGIS] #1686: [raster] mingw64 PostgreSQL 9.0 64-bit windows failure rt_io, rt_bytea, uninstall
PostGIS trac at osgeo.org
Wed Mar 14 06:56:16 PDT 2012
uninstall
 Reporter:  robe    |       Owner:  pracine
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.0.1
Component:  raster  |     Version:  trunk
 Keywords:          |
 rt_io failure
 --- rt_io_expected      2012-02-27 17:08:12 -0500
 +++ /tmp/pgis_reg/test_3_out    2012-03-14 09:45:12 -0400
 @@ -11,6 +11,7 @@
  1x1 single band (32BF) no transform|t|t
  1x1 single band (64BF) no transform|t|t
  1x1 single band (64BF external) no transform|t|t
 -ERROR:  rt_band_from_wkb: Invalid value 2 for pixel of type 1BB
 -ERROR:  rt_band_from_wkb: Invalid value 4 for pixel of type 2BUI
 -ERROR:  rt_band_from_wkb: Invalid value 16 for pixel of type 4BUI
 +server closed the connection unexpectedly
 +       This probably means the server terminated abnormally
 +       before or while processing the request.
 +connection to server was lost
 rt_bytea is also failing, but might be just because the system is coming
 back up after this.
 I'm not sure if this is because of changes to my environment or changes
 made.  This is what I get when compiling for PostgreSQL 9.0 Windows
 64-bit.  I'm going to recheck my 9.1 build next.
 I suspect its something different in my environment as topology is failing
 so horribly (topology: 20 out of 44 failed) I'm not going to bother
 ticketing it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1686>
