[postgis-devel] [PostGIS] #1688: Passing a bogus value to --with-jsondir=XXX does not make any noise
PostGIS trac at osgeo.org
Thu Mar 15 02:30:32 PDT 2012
 Reporter:  strk                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 Try ./configure --with-jsondir=/tmp
 It won't error out. It'll go looking around for your library and if found
 would tell you json is enabled.
 Didn't try not having the library but I suspect it would just tell you
 json is disabled.
 I think it should error out instead, as the user specification must be
 meaningful.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1688>
