[postgis-devel] [PostGIS] #1659: [raster] ST_Union raster out of memory then kicks the bucket on windows 64bit
PostGIS trac at osgeo.org
Thu Mar 15 16:42:07 PDT 2012
64bit
 Reporter:  robe                        |       Owner:  pracine
     Type:  defect                      |      Status:  new
 Priority:  medium                      |   Milestone:  PostGIS 2.0.1
Component:  raster                      |     Version:  trunk
 Keywords:  mingw windows 64bit, 32bit  |
Comment(by dustymugs):
 robe, can you retry this?
 Testing the example query in the Windows Experimental 64-bit PostGIS on
 PostgreSQL 9.1 in Windows 7 Pro results in the following
 NOTICE:  Neither raster provided has a NODATA value for the specified band
 indices.  NODATA value set to minimum possible for 16BSI
 CONTEXT:  PL/pgSQL function "_st_mapalgebra4unionstate" line 13 at RETURN
 SQL function "_st_mapalgebra4unionstate" statement 1
 ERROR:  invalid memory alloc request size 1137072672
 ********** Error **********
 SQL state: XX000
 Context: PL/pgSQL function "_st_mapalgebra4unionstate" line 13 at RETURN
 It isn't crashing out on me.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1659#comment:7>
