[postgis-devel] [PostGIS] #1690: Sort out ERROR: transform: couldn''t project point (180 -90 0): tolerance condition error (-20)
PostGIS trac at osgeo.org
Fri Mar 16 09:24:20 PDT 2012
  Reporter:  strk     |       Owner:  pramsey
      Type:  task     |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Comment(by tokumine):
 running on a newer build we're getting the following:
 select st_astext(ST_Transform('SRID=4326;POINT(180 -90)'::geometry,
 3857));
 ERROR:  transform: couldn't project point (180 -90 0): tolerance condition
 error (-20)
  POSTGIS="2.0.0alpha5SVN" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.7.1, 23
 September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.6"
 SVN_REVISION=9194 USE_STATS
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1690#comment:10>
