[postgis-devel] [PostGIS] #1690: Sort out ERROR: transform: couldn''t project point (180 -90 0): tolerance condition error (-20)
PostGIS trac at osgeo.org
Fri Mar 16 09:25:50 PDT 2012
  Reporter:  strk     |       Owner:  pramsey
      Type:  task     |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Changes (by strk):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Interesting, so _same_ PROJ version (4.7.1). The difference must be in
 PostGIS. Can you get the the SVN revision of PostGIS installed on the
 first machine, somehow ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1690#comment:11>
