[postgis-devel] [PostGIS] #1659: [raster] ST_Union raster out of memory then kicks the bucket on windows 64bit
PostGIS trac at osgeo.org
Fri Mar 16 11:54:48 PDT 2012
64bit
 Reporter:  robe                        |       Owner:  pracine
     Type:  defect                      |      Status:  new
 Priority:  medium                      |   Milestone:  PostGIS 2.0.1
Component:  raster                      |     Version:  trunk
 Keywords:  mingw windows 64bit, 32bit  |
Comment(by dustymugs):
 On repeated runs of the example query, PostgreSQL 9.1 with PostGIS 64-bit
 in Windows 7 crashes consistently.  It does run without crashing (query
 still fails) the first time the query is run but crashes on the second
 attempt.
 Repeated runs of the example query in 64-bit Linux with PostgreSQL 9.1 and
 PostGIS 64-bit does not result in a crash.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1659#comment:12>
