[postgis-devel] [PostGIS] #1701: regress failures - can we not overwrite loader error file?
PostGIS trac at osgeo.org
Wed Mar 21 19:21:14 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:  mingw64  |
 I'm getting a lot of mingw64 erros on loader.  One looks like just a
 rounding issue.
  PostgreSQL 9.1.3 on x86_64-w64-mingw32, compiled by
 x86_64-w64-mingw32-gcc.e
 (GCC) 4.4.7 20110510 (prerelease) [svn/rev.173611 - mingw-w64/oz], 64-bit
  Postgis 2.0.0beta4 - r9521 - 2012-03-22 02:03:16
    GEOS: 3.3.3dev-CAPI-1.7.3
    PROJ: Rel. 4.8.0, 6 March 2012
 Running tests
  loader/Point ....................... ok
  loader/PointM ....................... ok
  loader/PointZ ....................... ok
  loader/MultiPoint ....................... ok
  loader/MultiPointM ....................... ok
  loader/MultiPointZ ....................... ok
  loader/Arc ....................... ok
  loader/ArcM ....................... ok
  loader/ArcZ ....................... ok
  loader/Polygon ....................... ok
  loader/PolygonM ...... failed ( geog test: running shp2pgsql output:
 /tmp/pg
 reg/loader.err)
  loader/PolygonZ ...... failed ( geog test: running shp2pgsql output:
 /tmp/pg
 reg/loader.err)
  loader/TSTPolygon ......... ok
  loader/TSIPolygon ......... ok
  loader/TSTIPolygon ......... ok
  loader/PointWithSchema ..... ok
  loader/NoTransPoint ......... ok
  loader/NotReallyMultiPoint .... failed (wkt test: diff expected obtained:
 /t
 pgis_reg/test_18_diff)
  loader/MultiToSinglePoint ... failed ( wkt test: running shp2pgsql
 output: /
 /pgis_reg/loader.err)
  loader/ReprojectPts .... failed ( wkt test: running shp2pgsql output:
 /tmp/p
 _reg/loader.err)
  loader/ReprojectPtsGeog .... failed ( wkt test: running shp2pgsql output:
 /t
  loader/Latin1 .... ok
  binary .. ok
  regress .. ok
  regress_index .. ok
  regress_index_nulls .. ok
  lwgeom_regress .. ok
  regress_lrs .. ok
  removepoint .. ok
  setpoint .. ok
  simplify .. ok
  snaptogrid .. ok
  summary .. ok
  affine .. ok
  empty .. ok
  measures .. ok
  legacy .. ok
  long_xact .. ok
  ctors .. ok
  sql-mm-serialize .. ok
  sql-mm-circularstring .. ok
  sql-mm-compoundcurve .. ok
  sql-mm-curvepoly .. ok
  sql-mm-general .. ok
  sql-mm-multicurve .. ok
  sql-mm-multisurface .. ok
  polyhedralsurface .. ok
  polygonize .. ok
  postgis_type_name .. ok
  out_geometry .. ok
  out_geography .. ok
  in_gml .. ok
  in_kml .. ok
  iscollection .. ok
  regress_ogc .. ok
  regress_ogc_cover .. ok
  regress_ogc_prep .. ok
  regress_bdpoly .. ok
  regress_proj .. ok
  regress_management .. ok
  dump .. ok
  dumppoints .. ok
  wmsservers .. ok
  wkt .. ok
  wkb .. ok
  tickets .. ok
  typmod .. ok
  remove_repeated_points .. ok
  split .. ok
  relate .. ok
  bestsrid .. ok
  concave_hull .. ok
  hausdorff .. ok
  regress_buffer_params .. ok
  offsetcurve .. ok
  relatematch .. ok
  isvaliddetail .. ok
  sharedpaths .. ok
  snap .. ok
  node .. ok
  unaryunion .. ok
  clean .. ok
  relate_bnr .. ok
  in_geojson .. ok
  uninstall .. ok (3855)
 Run tests: 85
 Failed: 6
 make: *** [check] Error 6
 Anyrate I don't care so much about getting the errors as much as not
 knowing what they are.  the shp2pgsql overwrite the loader.err file so
 can't tell what the errors are if they are harmless or not.
 The multi to single point one looks like a rounding issue
 --- loader/NotReallyMultiPoint-w.select.expected        2011-03-18
 12:24:33 -0400
 +++ /tmp/pgis_reg/test_18_out   2012-03-21 22:11:29 -0400
 @@ -38,7 +38,7 @@
  MULTIPOINT(605633.269658534 771823.459750208)
  MULTIPOINT(318054.396825439 406677.968765208)
  MULTIPOINT(606814.490943 683559.837390652)
 -MULTIPOINT(427202.24558416 526355.921118875)
 +MULTIPOINT(427202.24558416 526355.921118876)
  MULTIPOINT(585605.654583162 428734.299958661)
  MULTIPOINT(348498.220290712 696622.254661199)
  MULTIPOINT(447753.888233448 552268.218021069)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1701>
