[postgis-devel] [PostGIS] #1706: TopoGeo_AddPolygon not adding polygons
PostGIS trac at osgeo.org
Thu Mar 22 10:00:53 PDT 2012
 Reporter:  pramsey   |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 I just took a polygon file
 that had contiguous non-overlapping polygons and did this:
 cded=# select TopoGeo_AddPolygon('sheds', st_geometryn(geom,1), 5.0)
 from sheds where gis_tag like 'VICT%';
 ERROR:  Spatial exception - geometry intersects edge 39
 CONTEXT:  PL/pgSQL function "topogeo_addlinestring" line 175 at assignment
 SQL statement "SELECT array_cat(edges, array_agg(x)) FROM ( select
 topology.TopoGeo_addLinestring(atopology, rec.geom, tol) as x ) as
 foo"
 PL/pgSQL function "topogeo_addpolygon" line 27 at assignment
 This is a non-overlapping set of data, originally generated from
 vector clean ArcINFO coverages...
 select a.gis_tag, b.gis_tag from sheds a, sheds b where
 st_overlaps(a.geom,b.geom) and a.gis_tag like 'VICT%' and b.gis_tag
 like 'VICT%';
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1706>
