[postgis-devel] [PostGIS] #1707: Regress on topology running make check - r9529
PostGIS trac at osgeo.org
Thu Mar 22 23:09:38 PDT 2012
 Reporter:  sindile  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
 PostgreSQL 9.1.3 on x86_64-unknown-linux-gnu, compiled by gcc
 (Ubuntu/Linaro 4.6.3-1ubuntu2) 4.6.3, 64-bit
   Postgis 2.0.0beta5SVN - r9529 - 2012-03-22 17:57:17
     GEOS: 3.3.2-CAPI-1.7.2
     PROJ: Rel. 4.8.0, 6 March 201
 Running tests
  regress/legacy_validate .. failed (diff expected obtained:
 /tmp/pgis_reg/test_1_diff)
  regress/legacy_predicate .. failed (diff expected obtained:
 /tmp/pgis_reg/test_2_diff)
  regress/legacy_invalid .. ok
  regress/sqlmm .. failed (diff expected obtained:
 /tmp/pgis_reg/test_4_diff)
  regress/legacy_query .. failed (diff expected obtained:
 /tmp/pgis_reg/test_5_diff)
  regress/addnode .. failed (diff expected obtained:
 /tmp/pgis_reg/test_6_diff)
  regress/addedge .. ok
  regress/addface .. failed (diff expected obtained:
 /tmp/pgis_reg/test_8_diff)
  regress/addface2.5d .. ok
  regress/addtopogeometrycolumn .. failed (diff expected obtained:
 /tmp/pgis_reg/test_10_diff)
  regress/polygonize .. ok
  regress/st_addisoedge .. ok
  regress/st_addisonode .. failed (diff expected obtained:
 /tmp/pgis_reg/test_13_diff)
  regress/st_addedgemodface .. failed (diff expected obtained:
 /tmp/pgis_reg/test_14_diff)
  regress/st_addedgenewfaces .. failed (diff expected obtained:
 /tmp/pgis_reg/test_15_diff)
  regress/st_changeedgegeom .. failed (diff expected obtained:
 /tmp/pgis_reg/test_16_diff)
  regress/st_createtopogeo .. ok
  regress/st_getfacegeometry .. ok
  regress/st_getfaceedges .. ok
  regress/st_modedgeheal .. ok
  regress/st_modedgesplit .. failed (diff expected obtained:
 /tmp/pgis_reg/test_21_diff)
  regress/st_newedgeheal .. failed (diff expected obtained:
 /tmp/pgis_reg/test_22_diff)
  regress/st_newedgessplit .. failed (diff expected obtained:
 /tmp/pgis_reg/test_23_diff)
  regress/st_remedgenewface .. failed (diff expected obtained:
 /tmp/pgis_reg/test_24_diff)
  regress/st_remedgemodface .. ok
  regress/topoelement .. failed (diff expected obtained:
 /tmp/pgis_reg/test_26_diff)
  regress/topoelementarray_agg .. ok
  regress/topogeo_addlinestring .. failed (diff expected obtained:
 /tmp/pgis_reg/test_28_diff)
  regress/topogeo_addpoint .. failed (diff expected obtained:
 /tmp/pgis_reg/test_29_diff)
  regress/topogeo_addpolygon .. failed (diff expected obtained:
 /tmp/pgis_reg/test_30_diff)
  regress/topogeometry_type .. failed (diff expected obtained:
 /tmp/pgis_reg/test_31_diff)
  regress/topo2.5d .. ok
  regress/totopogeom .. failed (diff expected obtained:
 /tmp/pgis_reg/test_33_diff)
  regress/droptopology .. ok
  regress/copytopology .. ok
  regress/createtopogeom .. failed (diff expected obtained:
 /tmp/pgis_reg/test_36_diff)
  regress/createtopology .. ok
  regress/gml .. ok
  regress/getnodebypoint .. ok
  regress/getedgebypoint .. ok
  regress/getfacebypoint .. ok
  regress/getringedges .. ok
  regress/layertrigger .. failed (diff expected obtained:
 /tmp/pgis_reg/test_43_diff)
  uninstall . failed (uninstall_topology.sql failed:
 /tmp/pgis_reg/uninstall.err)
 . failed (uninstall_postgis.sql failed: /tmp/pgis_reg/uninstall.err)
 Run tests: 44
 Failed: 25
 make[2]: *** [check] Error 25
 make[2]: Leaving directory `/home/sindile/dev/cpp/postgis-
 svn/topology/test'
 make[1]: *** [check] Error 2
 make[1]: Leaving directory `/home/sindile/dev/cpp/postgis-svn/topology'
 make: *** [check] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1707>
