[postgis-devel] What is the meaning if this NOTICE?
Sandro Santilli strk at keybit.net
Fri Mar 23 00:39:22 PDT 2012
On Thu, Mar 22, 2012 at 02:39:25PM -0400, Pierre Racine wrote:
> > > > > ERROR:  GEOSDifference: TopologyException: found non-noded
> > > > > intersection
> I could isolate the failing geometries:
Please save them. Then check if they are valid ST_IsValid.
If they are try to further reduce them (drop some vertices).
Whenever you're tired to do it report them in a ticket on
http://trac.osgeo.org/geos
I'll have to further reduce the dataset till I find the smallest
sample reproducing it, then check with JTS etc.etc.
Long way to figure things out.
Also, make sure you're using latest release of GEOS.
Thanks
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
