[postgis-devel] [PostGIS] #1707: Regress on topology running make check - r9529
PostGIS trac at osgeo.org
Fri Mar 23 02:22:20 PDT 2012
 Reporter:  sindile  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by sindile):
 here is the output from running make check RUNTESTFLAGS=-v
 tion block
 +psql:load_topology.sql:185: ERROR:  current transaction is aborted,
 commands ignored until end of transaction block
 +psql:load_topology.sql:188: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:191: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:194: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:197: ERROR:  current transaction is aborted,
  COMMIT
 -max|node|22
 -max|edge|26
 -max|face|9
 -ERROR:  Invalid geometry type (MULTILINESTRING) passed to
 TopoGeo_AddPolygon, expected POLYGON
 -ERROR:  Invalid geometry type (POINT) passed to TopoGeo_AddPolygon,
 expected POLYGON
 -iso_uni|10
 -N|23||POINT(36 26)
 -E|27|sn23|en23
 -F|10
 -iso_uni_hole|11
 -N|24||POINT(9 28)
 -N|25||POINT(15 25)
 -E|28|sn24|en24
 -E|29|sn25|en25
 -F|11
 -F|12
 -ex|4
 -ex_union|6
 -ex_union|7
 -half|4
 -E|30|sn14|en18
 -F|13
 -split|4
 -split|13
 -N|26||POINT(28 18)
 -E|30|sn14|en26
 -E|31|sn26|en18
 -E|32|sn17|en26
 -E|33|sn26|en13
 -F|14
 -F|15
 -ex_hole|3
 -ex_hole|5
 -ex_hole|6
 -ex_hole|7
 -ex_hole|8
 -ex_hole|13
 -ex_hole|14
 -ex_hole|15
 -ex_hole_snap|3
 -ex_hole_snap|5
 -ex_hole_snap|6
 -ex_hole_snap|7
 -ex_hole_snap|8
 -ex_hole_snap|13
 -ex_hole_snap|14
 -ex_hole_snap|15
 -Topology 'city_data' dropped
 +ERROR:  relation "limits" already exists
 +max|node|
 +max|edge|
 +max|edge|
 +max|face|0
 +ERROR:  function topogeo_addpolygon(unknown, unknown) does not exist at
 character 19
 character 19
 character 19
 character 24
 character 14
 character 20
 character 16
 character 17
 character 19
 +ERROR:  function topogeo_addpolygon(unknown, unknown, integer) does not
 exist at character 24
 +ERROR:  function droptopology(unknown) does not exist at character 8
  regress/topogeometry_type .. failed (diff expected obtained:
 /tmp/pgis_reg/test_31_diff)
 --- regress/topogeometry_type_expected  2012-03-22 17:49:10.948343421
 +0200
 +++ /tmp/pgis_reg/test_31_out   2012-03-23 09:54:22.737258284 +0200
 @@ -1,29 +1,120 @@
  BEGIN
 -t
 -9
 -22
 -26
 +psql:load_topology.sql:28: ERROR:  schema "city_data" already exists
 +psql:load_topology.sql:35: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:36: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:37: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:38: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:39: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:40: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:41: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:42: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:43: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:46: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:51: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:54: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:57: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:60: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:63: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:66: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:69: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:72: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:75: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:78: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:81: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:84: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:87: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:90: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:93: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:96: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:99: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:102: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:105: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:108: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:111: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:114: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:117: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:122: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:125: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:128: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:131: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:134: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:137: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:140: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:143: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:146: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:149: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:152: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:155: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:158: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:161: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:164: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:167: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:170: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:173: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:176: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:179: ERROR:  current transaction is aborted,
 +psql:load_topology.sql:182: ERROR:  current transaction is aborted,
  COMMIT
  BEGIN
  1
  2
  3
 +psql:load_features.sql:68: ERROR:  Face 3 does not exist in topology
 city_data
 +psql:load_features.sql:76: ERROR:  current transaction is aborted,
 +psql:load_features.sql:83: ERROR:  current transaction is aborted,
 +psql:load_features.sql:90: ERROR:  current transaction is aborted,
 +psql:load_features.sql:97: ERROR:  current transaction is aborted,
 +psql:load_features.sql:106: ERROR:  current transaction is aborted,
 +psql:load_features.sql:113: ERROR:  current transaction is aborted,
 +psql:load_features.sql:120: ERROR:  current transaction is aborted,
 +psql:load_features.sql:127: ERROR:  current transaction is aborted,
 +psql:load_features.sql:137: ERROR:  current transaction is aborted,
 +psql:load_features.sql:144: ERROR:  current transaction is aborted,
 +psql:load_features.sql:151: ERROR:  current transaction is aborted,
 +psql:load_features.sql:158: ERROR:  current transaction is aborted,
  COMMIT
 -4
 -features.big_parcels.the_geom SRID:0 TYPE:MULTIPOLYGON DIMS:2
 -5
 -6
 -features.big_signs.the_geom SRID:0 TYPE:MULTIPOINT DIMS:2
 -GeometryType(traffic_signs)|MULTIPOINT
 -ST_GeometryType(traffic_signs)|ST_MultiPoint
 -GeometryType(city_streets)|MULTILINESTRING
 -ST_GeometryType(city_streets)|ST_MultiLinestring
 -GeometryType(land_parcels)|MULTIPOLYGON
 -ST_GeometryType(land_parcels)|ST_MultiPolygon
 -GeometryType(big_signs)|MULTIPOINT
 -ST_GeometryType(big_signs)|ST_MultiPoint
 -GeometryType(big_streets)|MULTILINESTRING
 -ST_GeometryType(big_streets)|ST_MultiLinestring
 -GeometryType(big_parcels)|MULTIPOLYGON
 -ST_GeometryType(big_parcels)|ST_MultiPolygon
 +psql:more_features.sql:11: ERROR:  schema "features" does not exist at
 character 13
 +psql:more_features.sql:19: ERROR:  schema "features" does not exist at
 character 13
 +psql:more_features.sql:27: ERROR:  schema "features" does not exist at
 character 13
 +psql:more_features.sql:35: ERROR:  schema "features" does not exist at
 character 13
 +psql:more_features.sql:44: ERROR:  schema "features" does not exist at
 character 13
 +psql:more_features.sql:51: ERROR:  schema "features" does not exist at
 character 13
 +psql:more_features.sql:58: ERROR:  schema "features" does not exist at
 character 13
 +psql:more_features.sql:65: ERROR:  schema "features" does not exist at
 character 13
 +psql:more_features.sql:74: ERROR:  schema "features" does not exist at
 character 13
 +psql:more_features.sql:81: ERROR:  schema "features" does not exist at
 character 13
 +psql:more_features.sql:88: ERROR:  schema "features" does not exist at
 character 13
 +psql:more_features.sql:95: ERROR:  schema "features" does not exist at
 character 13
 +psql:hierarchy.sql:11: ERROR:  schema "features" does not exist
 +psql:hierarchy.sql:16: ERROR:  schema "features" does not exist
 +psql:hierarchy.sql:18: ERROR:  Schema 'features' is not a valid
 schemaname
 +psql:hierarchy.sql:25: ERROR:  schema "features" does not exist at
 character 13
 +psql:hierarchy.sql:32: ERROR:  schema "features" does not exist at
 character 13
 +psql:hierarchy.sql:42: ERROR:  schema "features" does not exist at
 character 13
 +psql:hierarchy.sql:50: ERROR:  schema "features" does not exist
 +psql:hierarchy.sql:55: ERROR:  schema "features" does not exist
 +psql:hierarchy.sql:65: ERROR:  schema "features" does not exist at
 character 13
 +psql:hierarchy.sql:75: ERROR:  schema "features" does not exist at
 character 13
 +psql:hierarchy.sql:83: ERROR:  schema "features" does not exist
 +psql:hierarchy.sql:88: ERROR:  schema "features" does not exist
 +psql:hierarchy.sql:90: ERROR:  Schema 'features' is not a valid
 schemaname
 +psql:hierarchy.sql:97: ERROR:  schema "features" does not exist at
 character 13
 +ERROR:  schema "features" does not exist at character 76
 +ERROR:  schema "features" does not exist at character 82
 +ERROR:  schema "features" does not exist at character 75
 +ERROR:  schema "features" does not exist at character 81
 +ERROR:  schema "features" does not exist at character 72
 +ERROR:  schema "features" does not exist at character 78
 +ERROR:  schema "features" does not exist at character 74
 +ERROR:  schema "features" does not exist at character 80
  regress/topo2.5d .. ok
  regress/totopogeom .. failed (diff expected obtained:
 /tmp/pgis_reg/test_33_diff)
 --- regress/totopogeom_expected 2012-03-22 17:49:10.960343477 +0200
 +++ /tmp/pgis_reg/test_33_out   2012-03-23 09:54:24.965269321 +0200
 @@ -1,35 +1,48 @@
 -create|t
 -ERROR:  No topology with name "unexistent" in topology.topology
 -ERROR:  No layer with id "1" in topology "tt"
 -ERROR:  No topology with name "" in topology.topology
 -simple_puntual_layer|1
 -hierarchical_layer|2
 -simple_lineal_layer|3
 -simple_areal_layer|4
 -simple_collection_layer|5
 -ERROR:  No layer with id "30" in topology "tt"
 -ERROR:  Layer "2" of topology "tt" is hierarchical, cannot convert to it.
 -ERROR:  Layer "1" of topology "tt" is puntal, cannot hold a lineal
 feature.
 -ERROR:  Layer "4" of topology "tt" is areal, cannot hold a lineal
 feature.
 -ERROR:  Layer "3" of topology "tt" is lineal, cannot hold a puntal
 feature.
 -ERROR:  Layer "4" of topology "tt" is areal, cannot hold a puntal
 feature.
 -ERROR:  Layer "1" of topology "tt" is puntal, cannot hold an areal
 feature.
 -ERROR:  Layer "3" of topology "tt" is lineal, cannot hold an areal
 feature.
 -POINT(0 0)|t
 -LINESTRING(0 10,10 10)|t
 -POLYGON((0 20,10 20,5 30,0 20),(2 22,8 22,5 28,2 22))|t
 -MULTIPOINT(0 -10,5 -10)|t
 -MULTILINESTRING((-1 10,-10 10),(-10 8,-2 9))|t
 -MULTIPOLYGON(((100 20,110 20,105 30,100 20),(102 22,108 22,105 28,102
 22)),((80 20,90 20,90 60,80 20)))|t
 -GEOMETRYCOLLECTION(POINT(-100 -100),LINESTRING(-100 -90,-90
 -90),POLYGON((-100 -80,-90 -80,-95 -70,-100 -80),(-98 -78,-92 -78,-95
 -72,-98 -78)),MULTIPOINT(-100 -110,-95 -110),LINESTRING
 EMPTY,MULTILINESTRING((-101 -90,-110 -90),(-110 -92,-102
 -91)),MULTIPOLYGON(((0 -80,10 -80,5 -70,0 -80),(2 -78,8 -78,5 -72,2
 -78)),((-20 -80,-10 -80,-10 -40,-20
 -80))))|GEOMETRYCOLLECTION(MULTIPOLYGON(((-100 -80,-95 -70,-90 -80,-100
 -80),(-98 -78,-92 -78,-95 -72,-98 -78)),((0 -80,5 -70,10 -80,0 -80),(2
 -78,8 -78,5 -72,2 -78)),((-20 -80,-10 -40,-10 -80,-20
 -80))),MULTILINESTRING((-110 -92,-102 -91),(-101 -90,-110 -90),(-100
 -90,-90 -90)),MULTIPOINT(-100 -110,-100 -100,-95 -110))
 -MULTIPOINT EMPTY
 -MULTIPOINT EMPTY
 -MULTILINESTRING EMPTY
 -MULTIPOLYGON EMPTY
 -MULTIPOLYGON EMPTY
 -GEOMETRYCOLLECTION EMPTY
 -tolerance_1|0.5
 -tolerance_topo_1|0.5
 -tolerance_0|0
 -Topology 'tt' dropped
 +ERROR:  function createtopology(unknown) does not exist at character 18
 +ERROR:  function totopogeom(geometry, unknown, integer) does not exist at
 character 8
 character 8
 +ERROR:  function totopogeom(unknown, unknown, integer) does not exist at
 character 8
 character 8
 character 8
 +ERROR:  function totopogeom(geometry, unknown, unknown) does not exist at
 character 8
 +ERROR:  schema "tt" does not exist
 +ERROR:  function addtopogeometrycolumn(unknown, unknown, unknown,
 unknown, unknown) does not exist at character 32
 unknown, unknown, integer) does not exist at character 30
 unknown, unknown) does not exist at character 31
 unknown, unknown) does not exist at character 30
 unknown, unknown) does not exist at character 35
 character 8
 character 8
 character 8
 character 8
 character 8
 character 8
 character 8
 character 8
 character 83
 character 96
 character 133
 character 100
 character 119
 character 186
 character 428
 character 18
 character 18
 character 18
 character 18
 character 18
 character 18
 character 18
 +ERROR:  function totopogeom(geometry, unknown, integer, integer) does not
 exist at character 218
 character 218
 character 218
  regress/droptopology .. ok
  regress/copytopology .. ok
  regress/createtopogeom .. failed (diff expected obtained:
 /tmp/pgis_reg/test_36_diff)
 --- regress/createtopogeom_expected     2012-03-22 17:49:10.980343581
 +0200
 +++ /tmp/pgis_reg/test_36_out   2012-03-23 09:54:31.545301953 +0200
 @@ -7,26 +7,26 @@
  ERROR:  Node 78 does not exist in topology MiX
  n1|1
  1|2|1
 -ERROR:  Invalid TopoGeometry type 5 (must be in the range 1..4)
 -ERROR:  Invalid TopoGeometry type 0 (must be in the range 1..4)
 -l2|2
 -n2|2
 -e1|1
 -ERROR:  A TopoGeometry of type 2 cannot contain topology elements of type
 1
 -L1|MULTILINESTRING((0 0,10 0))
 -l3|3
 -e2|2
 -f1|1
 -ERROR:  A Layer of type 3 cannot contain a TopoGeometry of type 2
 -ERROR:  A TopoGeometry of type 3 cannot contain topology elements of type
 2
 -A1|MULTIPOLYGON(((10 0,0 0,5 5,10 0)))
 -l4|4
 -MP|MULTIPOINT(0 0)
 -ML|MULTILINESTRING((0 0,10 0))
 -MA|MULTIPOLYGON(((10 0,0 0,5 5,10 0)))
 -MM|GEOMETRYCOLLECTION(POLYGON((10 0,0 0,5 5,10 0)),LINESTRING(0 0,10
 0),POINT(0 0))
 -POINT EMPTY|MULTIPOINT EMPTY
 -LINESTRING EMPTY|MULTILINESTRING EMPTY
 -POLYGON EMPTY|MULTIPOLYGON EMPTY
 -GEOMETRYCOLLECTION EMPTY|GEOMETRYCOLLECTION EMPTY
 -Topology 'MiX' dropped
 +ERROR:  function createtopogeom(unknown, integer, integer, unknown) does
 unknown, unknown) does not exist at character 14
 +ERROR:  function addnode(unknown, unknown) does not exist at character 14
 +ERROR:  function addedge(unknown, unknown) does not exist at character 14
 not exist at character 24
 +ERROR:  function addface(unknown, unknown) does not exist at character 14
 not exist at character 34
 not exist at character 39
 not exist at character 36
 not exist at character 47
  regress/createtopology .. ok
  regress/gml .. ok
  regress/getnodebypoint .. ok
  regress/getedgebypoint .. ok
  regress/getfacebypoint .. ok
  regress/getringedges .. ok
  regress/layertrigger .. failed (diff expected obtained:
 /tmp/pgis_reg/test_43_diff)
 --- regress/layertrigger_expected       2012-03-22 17:49:10.972343541
 +0200
 +++ /tmp/pgis_reg/test_43_out   2012-03-23 09:54:44.909368232 +0200
 @@ -4,13 +4,14 @@
  t2.l1|1
  t2.rel|1|1|1|1
  ERROR:  The topology.layer table cannot be updated
 +after update: topology.layer |61|1|MiX|poi|feat|1|0|
  after update: topology.layer |2|1|t2|l1|g|1|0|
  BEGIN
 -after delete n.1: topology.layer count|1
 +after delete n.1: topology.layer count|2
  COMMIT
  BEGIN
 -after delete n.2: topology.layer count|1
 +after delete n.2: topology.layer count|2
  COMMIT
 -after delete n.3: topology.layer count|0
 +after delete n.3: topology.layer count|1
  Topology 't2' dropped
  Topology 't1' dropped
  uninstall . failed (uninstall_topology.sql failed:
 /tmp/pgis_reg/uninstall.err)
 psql:/home/sindile/dev/cpp/postgis-svn/regress/00-regress-
 install/share/contrib/postgis/uninstall_topology.sql:33: ERROR:  cannot
 drop function topology.relationtrigger() because other objects depend on
 it
 DETAIL:  trigger relation_integrity_checks on table "MiX".relation depends
 on function topology.relationtrigger()
 HINT:  Use DROP ... CASCADE to drop the dependent objects too.
 . failed (uninstall_postgis.sql failed: /tmp/pgis_reg/uninstall.err)
 install/share/contrib/postgis/uninstall_postgis.sql:39: ERROR:  cannot
 drop operator class gist_geometry_ops_2d for access method gist because
 other objects depend on it
 DETAIL:  index "MiX".face_gist depends on operator class
 index "MiX".node_gist depends on operator class gist_geometry_ops_2d for
 access method gist
 index "MiX".edge_gist depends on operator class gist_geometry_ops_2d for
 access method gist
 Run tests: 44
 Failed: 25
 make[1]: *** [check] Error 25
 make[1]: Leaving directory `/home/sindile/dev/cpp/postgis-
 svn/topology/test'
 make: *** [check] Error 2
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1707#comment:3>
