[postgis-devel] [PostGIS] #1706: TopoGeo_AddPolygon not adding polygons
PostGIS trac at osgeo.org
Fri Mar 23 05:25:36 PDT 2012
 Reporter:  pramsey   |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 I shall add that the distance between vertices of the input geometries is
 sometimes < the given tolerance (5) which probably also affects operation.
 I suspect passing the inputs trough ST_SnapToGrid with a grid size ==
 tolerance would fix this case.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1706#comment:8>
