[postgis-devel] [PostGIS] #1706: TopoGeo_AddPolygon not adding polygons
PostGIS trac at osgeo.org
Fri Mar 23 10:35:01 PDT 2012
 Reporter:  pramsey   |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 Above you can see there are two very close-by vertexes on (9,12) but not
 quite the same. That vertex was the split point for the first edge added,
 found by noding the snapped verso of second edge against the first edge.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1706#comment:13>
