[postgis-devel] [PostGIS] #1706: TopoGeo_AddPolygon not adding polygons
PostGIS trac at osgeo.org
Fri Mar 23 10:36:55 PDT 2012
 Reporter:  pramsey   |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 Uhm but then again it does make sense for TOpoGeo_AddPoint to project the
 point, following the rule that whoever was there first (the edge) should
 drive operations (the point being added must snap to the existing edge,
 not the other way around)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1706#comment:14>
