[postgis-devel] [PostGIS] #1706: TopoGeo_AddPolygon not adding polygons
PostGIS trac at osgeo.org
Fri Mar 23 11:55:37 PDT 2012
 Reporter:  pramsey   |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 with inp as (SELECT
 '01020000000300000000000000000034400000000000002440000000000000244000000000000024400000000000002240FFFFFFFFFFFF2740'::geometry
 as e,
 '01020000000400000000000000000022400000000000002840000000000000244000000000000024400000000000002E40000000000000244000000000000034400000000000002440'::geometry
 as n ) select st_astext(e) as e, st_astext(n) as n, st_equals(e,n),
 st_hausdorffdistance(e,n), st_astext(st_symdifference(e,n)) as sd,
 st_equals(st_snap(n,e,1e-14), e) as snapequals, st_equals(st_endpoint(n),
 st_startpoint(e)) as new_end_equals_exs_start, st_equals(st_startpoint(n),
 st_endpoint(e)) as new_start_equals_exs_end,
 st_equals(st_snap(n,st_endpoint(e),5), e) as snap_to_lastpoint_equals from
 inp;
 The above shows that altough the problem is vertex (9,12) not being
 exactly the same, snapping the new edge to the existing edge makes them
 equal but snapping the new edge to _only_ the (9,12) vertex of the old
 edge does _not_ make them equal.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1706#comment:16>
