[postgis-devel] [PostGIS] #1706: TopoGeo_AddPolygon not adding polygons
PostGIS trac at osgeo.org
Fri Mar 23 13:49:49 PDT 2012
 Reporter:  pramsey   |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 New idea: the problem is in ModEdgeSplit:
 psql:bug.sql:1: NOTICE:  ModEdgeSplit: newedge1 endpoint does not match
 split point
 psql:bug.sql:1: NOTICE:  ModEdgeSplit: newedge2 startpoint does not match
 split point
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1706#comment:18>
