[postgis-devel] [PostGIS] #1719: Do not throw an exception on unsupported ST_MakeValid input (was: Add Point support in ST_MakeValid)
PostGIS trac at osgeo.org
Mon Mar 26 10:35:59 PDT 2012
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 Can't confirm the empty case:
 strk=# select ST_AsEWKT(ST_MakeValid('POLYGON EMPTY'));
    st_asewkt
  POLYGON EMPTY
 (1 row)
 But GEOMETRYCOLLECTION is a problem !
 trk=# select ST_AsEWKT(ST_MakeValid('GEOMETRYCOLLECTION EMPTY'));
 ERROR:  ST_MakeValid: unsupported geometry type GeometryCollection
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1719#comment:2>
