[postgis-devel] [PostGIS] #1720: Update extensions/README
PostGIS trac at osgeo.org
Tue Mar 27 02:48:49 PDT 2012
 Reporter:  mwtoews        |       Owner:  robe
     Type:  patch          |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.0
Component:  documentation  |     Version:  trunk
 Keywords:                 |
Comment(by strk):
 I think the explicit "make install" from within extensions/ should not be
 needed either, but rather "make install" from top-level build dir should
 do.
 Did you try ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1720#comment:2>
