[postgis-devel] [PostGIS] #1697: Crash in GiST index with empty MultiPolygons
PostGIS trac at osgeo.org
Tue Mar 27 08:07:58 PDT 2012
 Reporter:  realityexists  |       Owner:  pramsey
     Type:  defect         |      Status:  new
 Priority:  critical       |   Milestone:  PostGIS 2.0.0
Component:  postgis        |     Version:  trunk
 Keywords:                 |
Comment(by pramsey):
 Regarding memory and so on, bbox_out isn't returned, a gist entry is
 returned, and in cases where a box is embedded in the gist entry as a key,
 the box is copied before returning. I carefully set this up to avoid
 global allocations, don't worry about that stuff. The problem is not
 there, it's in how we handle empties in the compress routines.
 Regarding fixing, now that I know where the problem is, fixing becomes
 quite possible, but will take some time to try different things and test.
 As noted before, this problem has existed in 1.5 for a long time in the
 geography type, so I don't think we should necessarily block on it unless
 we really really want to.
 What surprises me is when I try to return an empty gist entry, aping the
 null handling, I get a crash, so I must be doing something wrong in my
 aping.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1697#comment:14>
