[postgis-devel] [PostGIS] #1727: Fix unpackaged install for extensions
PostGIS trac at osgeo.org
Tue Mar 27 16:19:12 PDT 2012
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  closed
  Priority:  medium                 |   Milestone:  PostGIS 2.0.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:  fixed                  |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 fixed at r9561.  this is more of a stop gap.
 The generation I had ran using the sql script in
 extensions/make_unpackaged.sql
 Will deal with elegance later.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1727#comment:1>
