[postgis-devel] [PostGIS] #1730: layerid in GetTopoGeomElementArray
PostGIS trac at osgeo.org
Wed Mar 28 03:19:45 PDT 2012
 Reporter:  chrizke   |       Owner:  chrizke
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 Using topology.GetTopoGeomElementArray throws the following exception:
 ERROR:  Column »layerid« doesn't exist
 LINE 3:     || quote_literal(layerid) || ','
 QUERY:  SELECT 'SELECT * FROM topology.GetTopoGeomElements('
     || quote_literal(toponame) || ','
     || quote_literal(tgid)
     || ') as obj ORDER BY obj'
 CONTEXT:  PL/pgSQL function "gettopogeomelementarray" line 9 at ...
 I think it should be:
 quote_literal(layer_id)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1730>
