[postgis-devel] [PostGIS] #1728: measures regression test fails in 1.5 branch
PostGIS trac at osgeo.org
Wed Mar 28 04:04:09 PDT 2012
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.4
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Comment(by nicklas):
 I do get the same wrong answer at 64 bit (297.5)
 It seems like r9273 is the problem. It works as expected on r9272.
 But I double checked and 32 bit seems to work as expected also with the
 change in r9273.
 I don't see what in that change that can give different answers in 32-bit
 and 64-bit.
 Sandro, you mention that r9273 removes a compiler warning, can that be a
 clue?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1728#comment:4>
