[postgis-devel] [PostGIS] #1728: measures regression test fails in 1.5 branch
PostGIS trac at osgeo.org
Wed Mar 28 04:32:18 PDT 2012
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.4
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Comment(by nicklas):
 You are right that the problem is there.
 If I revert just that part of the commit it works as expected.
 The same error appears with this simplier polygon:
 select
 area2d('POLYGON((5 5, 7 5, 7 7 , 5 7, 5 5) ) '::GEOMETRY)
  as value;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1728#comment:7>
