[postgis-devel] [PostGIS] #1728: measures regression test fails in 1.5 branch
PostGIS trac at osgeo.org
Wed Mar 28 04:38:58 PDT 2012
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.4
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Comment(by strk):
 right! Sorry about that. We should check if the same problem is in trunk
 too.
 I think first thing is adding a test making this clear, and possibly
 breaking both 32 and 64bit systems. Probably any polygon not starting with
 0,0 would do. The bigger numbers to clearer.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1728#comment:9>
