[postgis-devel] [PostGIS] #1734: Crash in GiST index on inserting geography Point
PostGIS trac at osgeo.org
Thu Mar 29 01:22:05 PDT 2012
 Reporter:  realityexists  |       Owner:  pramsey
     Type:  defect         |      Status:  new
 Priority:  critical       |   Milestone:  PostGIS 2.0.0
Component:  postgis        |     Version:  trunk
 Keywords:                 |
 When I run my application against PostGIS r9575 it crashes when inserting
 a perfectly ordinary geography Point (with a GiST index defined on the
 column). The point is specified as
 ST_GeomFromEWKT('SRID=4326;POINT(-2.7546111 8.0365000)')::geography
 and the stack trace is attached.
 This happens on 32-bit Linux on a newly created database. PostgreSQL
 9.1.3.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1734>
