[postgis-devel] [PostGIS] #1739: Problem with soft extension upgrade
PostGIS trac at osgeo.org
Thu Mar 29 11:01:52 PDT 2012
 Reporter:  otto                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  2.0.x
 Keywords:                         |
 I have 2.0.0b2 installed as an extension. Shouldn't I be able to do a soft
 upgrade to rc1?
 When I run the following:
 ALTER EXTENSION postgis UPDATE TO "2.0.0rc1";
 I get:
 ERROR:  cannot drop cast from geometry to geometry because extension
 postgis requires it
 HINT:  You can drop extension postgis instead.
 ********** Error **********
 postgis requires it
 SQL state: 2BP01
 Hint: You can drop extension postgis instead.
 I'm running pgsql 9.1.2 on OSX 10.6
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1739>
