[postgis-devel] [PostGIS] #1739: Problem with soft extension upgrade
PostGIS trac at osgeo.org
Thu Mar 29 22:11:49 PDT 2012
  Reporter:  otto                   |       Owner:  strk
      Type:  defect                 |      Status:  closed
  Priority:  medium                 |   Milestone:  PostGIS 2.0.0
 Component:  build/upgrade/install  |     Version:  2.0.x
Resolution:  worksforme             |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => worksforme
Comment:
 Okay I just installed beta2 and then installed rc1 and then upgraded my
 beta2 to rc1 and didn't run into any problems.
 The only time I've seen an error similar to what you have there is when I
 tried to move the schema of my postgis extension to another schema.
 Though I just tried that now and magically it worked -- it let me move the
 postgis extension to my topology schema and all the functions and types
 moved and views (except for 2 functions) now show up in topology schema
 yeah.  Have to investigate why those didn't move (they might some how be
 left out of extension or maybe they are from beta2 that our drop script
 didn't remove.  I'll put a separate ticket in for that one.
 I'm running PostgreSQL 9.1.2 as well but on windows.
 You might want to first try first by backing up your database and then
 restoring.
 Restore I think always ends up picking up the latest version.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1739#comment:3>
