[postgis-devel] Raster support in 2.0.0
Devrim GÜNDÜZ devrim at gunduz.org
Fri Mar 30 04:08:35 PDT 2012
Anyone?
On Thu, 2012-03-01 at 20:02 +0100, Devrim GÜNDÜZ wrote:
> Hi,
> I began testing packaging PostGIS for Fedora/RHEL/Scientific
> Linux/CentOS and others. So far it seems pretty fine, but I'm having
> some issues with raster support.
> To add raster support to PostGIS, I need to install gdal-devel package,
> and the current gdal package in Fedora/EPEL repositories are not aware
> of the new PostgreSQL RPM layout. I can make it aware, but then:
> 	armadillo-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	cfitsio-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	CharLS-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	chrpath is needed by gdal-1.9.0-1.f16.x86_64
> 	freexl-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	hdf-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	hdf-static is needed by gdal-1.9.0-1.f16.x86_64
> 	hdf5-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	jasper-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	libgta-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	libspatialite-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	netcdf-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	libdap-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	librx-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	mysql-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	numpy is needed by gdal-1.9.0-1.f16.x86_64
> 	ogdi-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	poppler-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	xerces-c-devel is needed by gdal-1.9.0-1.f16.x86_64
> 	xz-devel is needed by gdal-1.9.0-1.f16.x86_64
> and it means more build dependency to RPM buildfarm.
> So, the question from the "non-GIS and just a packager guy" is: How
> critical is raster support? Is it ok if I just ditch it out from the
> spec file?
> Regards,
Devrim GÜNDÜZ
Principal Systems Engineer @ EnterpriseDB: http://www.enterprisedb.com
PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
Community: devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
http://www.gunduz.org  Twitter: http://twitter.com/devrimgunduz
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120330/13defaaf/attachment.sig>
