[postgis-devel] Confusing output from configure for GDAL?
Nicklas Avén nicklas.aven at jordogskog.no
Fri Mar 30 05:11:36 PDT 2012
Mark
I ran into this problem the other day:
http://wiki.postgis.org/pipermail/postgis-users/2012-March/033114.html
It was caused by something messed up when installing QGIS from repo
(with both gdal 1.6 and 1.8 as dependences!)
So at least sometimes configure gets aborted by not finding
GDALAllRegister.
/Nicklas
On Fri, 2012-03-30 at 13:02 +0100, Mark Cave-Ayland wrote:
> Hi all,
> When I do a configure in SVN trunk, I see the following output although
> configure does succeed:
> checking for library containing GDALAllRegister... none required
> checking for library containing GDALFPolygonize... none required
> Does this mean that my GDAL doesn't contain either of these functions
> and so therefore should abort?
> ATB,
> Mark.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
